1 - 16 of 16 Posts
My back washer and wipers are working fine, however when I go to use the front washer the wipers work but it will not spray the washer fluid (yes the chamber is full) seems like this should be any easy fix.... Any help would be greatly appreciated...
check to see that the washer pump is getting power.
they are located in the front---- undo the wheel well screws- and pull back the liner-- youll see both.
You may be able to swap connectors and see if the the other pump runs...
I dont recall if each one has a fuse.
(do you hear the front one run at all?)
I can't tell if the motor is running. I will check it out when I get home and hope this works. I don't want to deal with taking it in to the dealership! Thanks!
do it with engine off- door open and you should be able to hear it--- fairly loud once you pay attention.
if you do hear it--- then its more likely a loose hose.
check for puddled fluid under the car.
look behind the wheel well- the motors are easily accessible.
(Someone with an Outlook recently had the same problem and it was the pump motor itself I believe).
drivers side- remove few screws and youre able to access area behind wheel well.
have someone press the button- and see if you can hear/fell the motor turn.
If not- swap the motor connections and see if you can get the motor to spin with the other connection (if the connections will fit) or take a meter reading at the contact points.
Again thanks so much.. I hope it isn't the motor. I have an extended warranty but was told they didnt think it would be covered :( I havent seen any leaks but havent really paid that much attention to it!
What type of extended warranty? If it is a GMPP Major Guard, the pump would be covered.
I am having a similar problem. 2011 Traverse LT. Front Wiper/Washer button only activates the wipers, no washer fluid spraying (full tank of fluid). I swapped out the 10 amp fuse in the interior fuse box (which did not appear to be bad) but it did not correct the problem. I then installed a new pump and, again, same result. I next checked the Wiper/Washer 25 amp fuse in the fuse box under the hood and that appears fine though I did not replace it. I do have a volt meter but may need someone to walk me through how to use it to test for power to the pump. I plan to swap the front and rear power plugs to the opposite pumps but I don't anticipate seeing a different result. Any suggestions are greatly appreciated!!
If you have a volt meter, check for 12VDC across the pump connector. The black wire on both pumps is ground; the other wire should have +12VDC. In other words, put your "plus" voltmeter lead on the colored wire's pin and the "minus" or ground voltmeter lead on the black wire's pin. Should read 12VDC.
BEFORE you do that: Both pumps have relays in the inside fuse box on the passenger side. See page 10-37 in the 2011 owner's manual. If one pump works and one doesn't, try swapping the relays and see if the problem swaps to the other pump.
Chevy Killeen wanted to keep my traverse for a week. For my front windshield washers not working. Back worked. Check the fuses under the hood . Under the dash. No problems. Check the nozzle and etc. Didnt really want to check the pump. Went online to a Buick enclave forum. Read where a guy said his was the airbox after he followed the line. Yea che y cause my problem when they change my airfilter. Unscrewed the box and pulled the hose out. Took care of the problem lol. I thought I was going crazy and the idiot customers service guys at Chevy are no help. Certified mechanic smh. They act like chevy is paying them commission like the quick lube RIP off places.
Posted about this many years ago.
Even had a diagram of where to look for the crimped hose...
The 2011 traverse has a faulty hose on the driver side of vehicle open the hood and at the hinge where the hoses run up from the fender to the hood the line cracks check that first before even thinking of spending money on random parts
Same issue here, unable to solve, dont want to take to dealership. Wipers work, front fluid pump does not. Checked fuses & relays, replaced front pump with new only to realize that was not the issue, swapped front and back pumps to test, swapped front and back relays to test. Back works fine, front makes the relay click but pump will not run. Any ideas?
I have the same problem as this last post, i can hear a click from the relay when i push the button, motor not activating @ front 2012 traverse, rear is working as well as wipers front and back, not sure what to try next
Go up and read my response in Post #9. Also, I just posted wiring diagrams in Post #17 here:
Hope they help.
1 - 16 of 16 Posts
