I noticed my passenger side low beam headlight was out about a week ago. Since then my front right turn signal and passenger side high beam have stopped working in that order. I suspect a fuse problem but with them all going out like this I’m afraid it’s something bigger. Anybody got any advice?
Headlamp is a separate fuse from the signal lights.Could it be all of the lamps failed at the same time? yes.
The high beam and low beams are separate fuses as well. It could be a bad connection in the fuse box under the hood.
If not check the common ground. What year?
