I have 2018 Traverse that just had some body work done, including replacing the headlamps. I'm wondering if this is normal:
1. Low beam lights on, pull lever back, high beams stay on until I release the lever
2. Low beams off, pull lever back, high beams come on for 1 second and then immediately go off while the lever remains pulled back.
Reading the manual it says the high beams should remain on until you release the lever, either with low beams on or off.
