My 2011 traverse has 260000 miles on it.Should I replace muffler and resonators or just keep driving.It sounds fine but I thought maybe it would have a lot of carbon buildup after so many miles.Any info appreciated.
If your muffler and resonator is in good shape I would leave it as it is. You must be doing a lots of highway miles. Small trips around
the blocks is what destroy exhaust system. Always wet inside.
Most mufflers these days are stainless steel, no replacement needed. That's why you don't see many muffler shops around anymore. Sometimes catalytic converters need replacement, but I believe you'll get a CEL for that.
I have 2012 traverse. Some weeks before I noticed the colling temperature gauge is rise little bit up and then come back at the normal position. It happened mostly in traffic or at the signal. so I replaced the thermostat with housing and coolant also. Things become normal, but now from 2 days its happening again. I used the scanner and checked the coolant temperature, at normal temperature 95C fan do not turn on. When temperature rise above 100C (I noticed at 105C) fans turned ON.
When I switch ON AC then temperature stay on normal.
What can be a problem? My guess is the temperature sensor. If I replace then the problem will solve? and is any computer setting required for sensor replacement?
Exhaust systems are made out of better materials these days and with the unleaded fuel have been lasting the life of the car. If your fuel mileage is good, power is good then it's not clogged up. The catalytic converters could wear out later but that will set a code. If it ain't broke .....
260K!!?!??! You should just replace the car! lol
You should write a book about how you kept it rolling for so long. Our 2011 have 170K and it is a month to month situation about how much longer it will run and we will be lucky to get $2K when we trade it in
Congrats on your Traverse mileage. As stated above, no need to replace mufflers and/or resonators until they develop holes or they get loud from internal wear and tear. I've never experienced or heard of these items getting clogged with carbon buildup. Also as stated above, if there was anything you might want to replace before it goes out is the catalytic converters. Wouldn't be cheap, but if they clog up they can leave you stranded. Would be an expensive replacement. I've got 382,000 miles on my '96 Dodge Ram and I've replaced the converter on it twice - first time just came apart and started rattling, second time it clogged up and left me stranded on the side of the road.
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
Traverse Forum
120K posts
36.1K members
Since 2008
A forum community dedicated to Chevy Traverse owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, maintenance, and more!
