Have a 2018 Redline 54k had since 3miles
Been having an exhaust issue trying to see if I am the lucky guy or if it's a common issue. Where the exhaust connects to header it goes down into a y and the exhaust run parallel to one another. Where it is running parallel there is a brace holding the exhaust. The welds at this point have cracked leaving a hole in the exhaust 2 times on the catalytic converter end of the y and have been covered under warranty. This time it is cracked on the other side and not covered. Dealer wants $980 to replace the pin hole in the exhaust caused by the cracked weld on the brace.
Seems like a tension issue to me seeing as there is no damage to the vehicle undercarriage.
