power steering makes noise want to check level but can not figure out how to take engine cover off. well it snap off or are those star shape screws come out if so what style are they as they are not a torx.
thanks doug
Just remove the oil filler cap first. Grab just one corner up at a time up and it will come up. Very easy. I check mine under this secret cover to see if there are no rodents starting a new house. Lol. For reinstall do the reverse by pushing down one corner at a time making sure they are lined with the pins until they snap. Those torx screws are just fake.
Like Capucine said.
the oil cap needs to be removed.
then you can pull up- at the corners.
and make sure- when you put back on--- to push down on the corners, you will feel a gentle pop as it pops into place. (onto the nipple ends of the studs)
Youll see what I mean when you remove it.
