21 - 36 of 36 Posts
Is it possible the dealer quietly made a software update to the OLM? and didnt tell you on paperwork?
Discussion Starter #23
I did not go to the dealer prior to the DIY oil change, unless they can update it with Onstar without a subscription. Everything seems normal before the DIY! Tonight I got a check engine light, but I don't have a code reader. The check engine light disappeared after three separate trips (2x30KM and 1x5KM). I will try to replace the FRAM oil filter with a Delco PF63e. Crossing my fingers hoping the weather will turn nice so that I don't get numb fingers.
I suspect that changing your filter is NOT going to solve your problem; but at least it will get you looking somewhere else. You can take it to your local auto parts store next time the CEL comes on and they can lend you a reader to see what the codes are.
Discussion Starter #25 (Edited)
I replaced the filter today. The OEM filter PF63E from the dealer is cheaper than the FRAM and Mobil1 that I bought! When I try to remove the FRAM XG10575 it was really tight. I hand tighten it myself when I install it and I need all sorts of tools to remove it today. The cover plate sure look different between the OEM and FRAM. The cover plate on the OEM (left) is flat. I don't know that matters or not. I only traveled 1050KM with the FRAM filter and the oil is pretty brown already.
It doesn't take long to get brown. Doesn't matter what filter you have.
Let us know when the CEL comes on again.
Does the Fram have that rubber grip on the top? That is one reason why I Used to buy Frams, they were easy to spin off when the time came. You can get those oil filter end cap attachments which fit into the flutes and then use a ratchet. The clearance on the Traverse should alloy it, on an Equinox it's a different story. The K&Ns have a welded hex which you can use a 1" wrench on, which is helpful, rather, necessary on the Nox.
Discussion Starter #28
Yes, the FRAM has the rubber grip on the top. I hand tighten the filter myself when I put it on few weeks ago and I can't move it a bit with my bare hands when trying to take it off! The location of the filter has little room to work in. I only able to use one hand trying to undo the filter. After fiddled it for half an hour, I managed to unscrew it off the thread using an adjustable socket type oil filter wrench.
Never had an issue removing an oil filter I installed with my bare hands or at most with nitrile gloves on... Couple times I've worked on vehicles serviced by dealers or quick-lubes those filters required strap wrenches or the old screwdriver poke through.
what is that stuff on top of the used filter?
Is it disintegrated media or did you wipe it with a towel that left behind pieces of towel?
yes- post 25
Discussion Starter #34
RBarios, you have good eyesight. That was a piece of paper towel that got left behind after I wiped the top to take the picture.
I am not driving the Traverse often enough lately, so I can't update the result after I switched the oil filter from FRAM XG10575 to AC Delco PF-63E. The temperature gauge on my traverse do came down a little. Now it is right at the half way mark. I will update the OLM percentage after I run the vehicle long enough.
Merry Christmas to all.
Hi all,
Previous oil changes on my 2015 Traverse were performed by the dealer. The cost keeps going up that I decided to do it myself. I installed Mobil 1 oil and a FRAM XG10575 in early November before the weather turns cold. The FRAM filter is shorter than the ACDelco oil filter, yet I had no problem installing the FRAM oil filter despite other members indicated they had problems with the threads. After driving the first 80KM, the OLM dropped from 100% to 98%. I noticed that the engine seems running hotter than before. Usually the temperature gauge marker points below the half way mark, now it is slightly above the half way mark. I checked my previous oil change records and found on average the OLM drops 1% every 120+KM with GM dealer oil and ACDelco PF63 filter. The OLM reading with Mobil 1 oil and FRAM XG10575 drops 1% after traveled 80+ KM on average.
I read few articles in the forum and found few members indicated FRAM XG10575 is not the correct filter for a Traverse, but all auto shops I visited indicate XG10575 is a suitable replacement for the ACDelco PF63.
  • Do FRAM XG10575 works on a 2015 model?
  • Is it possible that the smaller size oil filter limiting the flow of oil and is causing the engine overheating?
  • Should I pull out the FRAM oil filter and replace it with a Mobil M1-212 immediately (not crazy doing that because it is cold outside)?
Many thanks.
were you, I would just change out the filter with the Mobil One, I use that one a lot as well as the K&N and Wix. I haven't watched all the videos but the Wix and K&N are up there in Quality construction.
[/QUOTE]
Hi all,
Many thanks.
Don't use Fram ! The AC Delco PF 63 E, is one I won't use either, due to the filter media is glued to the filter head. I try to use only Wix, or Napa, { same thing }. Wix is still the official nascar oil filter. It also has far more filter element than the Frams, plus a bypass valve. I have been called out to a breakdown caused by the case getting blown off, from no bypass valve, in subzero weather. Still had to use a Fram, to get the car back to the garage.
21 - 36 of 36 Posts
