1 - 10 of 10 Posts
In my 2LT '15 Traverse with ambient lighting, only the two semi silver trim strips glow blue at night when the option is turned on, the silver trim strip around the A/C vent in the center of the dash does not. Shop manual electrical schematic shows three LEDs for this circuit, left, right and center. Can't get a straight answer on this from Chevy or brochures on whether the center trim strip is also supposed to light up with the ambient light option and mine is broken, or if center refers to the LED in the overhead console. None are in local showrooms for reference.
Update - Found one....seems the third LED is the one in the overhead console that lights the lower console area.
My 2016 LT-2 has the same ambient lighting pattern. The two curved end dash sections light up, but the center does not. Like you, I was wondering if mine was defective, but I guess not.
Just curious, where is the upper center console LED light you refer too? I have the dual moon roof option in mine, and the only light in the console, besides the map/reading lights, is the back light for the moon roof switch.
There is a small square 1/8" hole located in the center midway between the 2 map light buttons and the 3 homelink buttons......the LED is recessed and not visible from the side when lit.....projects downward onto the console and visible when looking straight up at it or shining on the console cup holders at night. GM can't seem to come up with a uniform lighting system between model lines.......surprised that only the dual moonroof buttons are lit......Homelink buttons in the Avalanche are also lighted. Worse the gear selection is shown only in the driver display, all letters remain white on the console....the Malibu also shows it in the driver display, but the light for the selected gear on the console changes from white to red when the gear is selected.
Thanks for the reply, Thomcat. I'll have to check that location on my console. If the hole is there, I'm sure the LED in my 2 month old car is shot, as I get no illumination on the cup holders area at night. I wish they had left the ambient light rings around the cup holder edges that were present a few model years ago. They used to have back lighting on the HomeLink buttons as well.
my 2010
ABC123
Found the center LED, and it works. It sure doesn't throw much light, and doesn't seem to be worth the effort. Maybe it you are driving on a moonless night in the country...
the light is dimmable with the dash lights.
But thats exactly where the light 'shines' its best.
In places where there arent many streetlights.
Gives a gentle glow that is great.... No need to turn on map lights when driving on some of those long dark highways.
I give it a big thumbs up!
I just purchased a used 2017 Traverse and on the dash the ambient lighting only lights on the drivers side. Is it just a light bulb that needs to be replaced on the passenger side? Is this something I can do myself? I'll probably never find my way back to this website, but it would be helpful if you could email me. Cheryl
I have 2020 Traverse RS and I had blue ambient lighting on the silver going across the dash and I’d swear I had a light in my glove box. Got my windshield replaced and now those lights don’t work. I went back to Chevy service to get it fixed. They’re trying to tell me those lights never existed. I know for a fact that I had blue ambient lighting. I’m so mad. I can’t find anything online about it.
I think your dealer is correct. I had a 2015 that had ambient lighting that operated off a separate button that was under the headlight switch as someone else has posted. I now have 2020 premier that does not have ambient lighting nor a light in the glove box. And looking at the Chevy site it is not an option you can order on the car.
1 - 10 of 10 Posts
