Dash cam stays on because
6.2K views 4 replies 4 participants last post by  Crossedover09
#1 ·
Dash cam stays on because the plug does not cut power. I know in some cars it stays on for a few minutes after locking the doors. But i have checked for hours and it just stays on.
Is there anything i can check to fix this.
Its the 12v cigarette charger inside the center console.
#3 ·
Many dash cams like mine have cigarette lighter adapters that drop the 12 volts to the 5 volt mini USB plug they use for cam power......usually these cams power input is a mini USB port used for PC interface to download from, a mini SD card. If so you can use a mini USB to USB cable leaving the two (red/black) power wires and cutting the two data wires to power the cam and plugging into a USB port that is not active with the ignition off.
