Love my son's Subaru BRZ filter. Right on top and self-draining!!!
Thanks brother. I will use that on my purchase.
according to my scanner. It goes as low as 572rpm then up to 731rpm and holds for 3 seconds then drops down under 600rpm and then back up again.Is the idle "hunting" ( fluctuating up and down) ?
I don’t have tb spray I’ve been using brake cleaner on everything else. I do have some starter fluid. I’ll try that tomorrowI've heard that if you disconnect the MAF while running the car should turn off and if not the MAF is bad. Have you tried the throttle body spray?
I also found my air leak.
Idle doesn’t hunt when the air leak is minimized
