Hello, I need a battery for my Traverse 2009. The problem is that I live in Europe. The battery in Europe is called in AH, ampère. Not in CCA. Does anyone know how Many amps the battery is. Traverse 2WD 2009. Thanks Marc Netherlands
Here's a link where the Poster shows the battery has a label stating 80 AH 330 load test.
http://www.traverseforum.com/6-general-discussion/4583-oem-battery.html
Here's a link about Battery ratings.
http://mathscinotes.com/2016/12/relationship-between-battery-cold-cranking-amps-versus-capacity/
CCA is how much current the battery can supply in a short amount of time (usually 30 seconds), Amp-hours is how long the battery can output a certain current.
The battery manufacturers should show both ratings.
A battery around 80 AH should work.
My 2010's factory battery label showed.
730 CCA, 70 Ah.
The Replacement AC DELCO I Put in was
770 CCA, 70 AH
