"ALL WHEEL DRIVE IS OFF" in message center
35K views 2 replies 3 participants last post by  ls973800
Voltage will do it-- if it falls below 9.5 volts. (battery factory?).
What you may be seeing is the Alternators output.... which is fine...
but what is battery voltage after sitting overnight?
AWD also turns off if it finds one tire is significantly smaller than the rest.
but since youre also getting ABS and traction lights-- the AWD is prob being turned off as a Safety mechanism.
