I saw something this weekend that I simply could NOT believe and have never seen before in any vehicle I've owned with factory air conditioning.
The air conditioning will NOT operate when the outside temperature is lower than 40F (4C). When you try to enable it, the light blinks several times and goes off. This is explained in the manual.
Out here in the humid Northwest, we use the air conditioner to get rid of the window fogging. Set-up the climate control to blow with heat through the windshield vents but with AC enabled. Works much much faster in the entire vehicle when the air conditioning is enabled. Without the air conditioner it takes longer to defog the windshield and driver/passenger windshields and the rear side windows will be fogged for a long long time. Load a bunch of cold wet soccer players into your vehicle and then see what happens (we play Sept to March). You need every edge you can get.
In essence, you use the air conditioner as a de-humidifier.
I've used this feature in my previous vehicles and dozens of rental cars over the years in winter conditions down to -38C.
What's with this in the Chev?
