1 - 17 of 17 Posts
Good job! I have a feeling you have used synthetic oil from day one, followed the recommended service schedule and didn't use cheap fuel.
Discussion Starter #8
Synthetic oil since 3000 miles and changed by the oil change light which is usually about 7500 and have always used 89 octane.cleaned throttle body every 30000 miles.K/n filter since 5000 too.It has never used oil even at 7500 mile oil change.Excellent SUV
Discussion Starter #10 (Edited)
Transmission services?
Brakes?
Serpentine Belt?
Plug s and Coils?
Transmission fluid at 75000 then every 50000 GM. GM
Front brakes 88000/178000/230000/Oreillys
Rear brakes 140000/220000 Oreillys
Water pump and serpentine belt 170000 Oreillys. Ac/Delco SPARK PLUGS
Plugs 102000/205000. Original coils
Original cats/and exhaust /timing chain
Shocks /struts 140000./Monroe premium
Steering rack/43000😡 extended warranty
Oxygen sensors/150000/250000 upstream
Downstream/170000. BOSCH.
All maintenance except steering rack was from myself. Only been to dealer service three times
Check engine light at 30000 first time cleaning throttle body. I didn’t know you should take the key out when you push butterfly open to clean 😂
Steering rack 43000
Front brakes 88000
First 150000 Pennzoil ultra then Royal Purple Hps or hmx either one
Discussion Starter #12
:oops::oops::oops::oops::oops:
Dang!
Thanks for the recap.
2nd question... Were all the replacement parts GM, or aftermarket?
I added to the original post. Can you keep me updated on your new traverse because we are gonna buy another next year or when this one dies.By then it will have over 300000 though🤞🏻
Wow! Your Traverse is really looking brand new. The way your are adding the miles I am sure you will be able to reach 1/2 million miles.
Reactions: mckay99
Great job man! Best thing I've done to my 2013 Traverse is swap PS/Tranny fluid with Shaffer ATF. No more PS whine or groan. Replaced alternator @ 125k. Only non related regular maintenance I've done. Well I did do end links twice. I hope mine goes as far as yours has!
Was a "part time delivery specialist" for O'Reillys. Its no wonder they can give "lifetime warranty" with the markup on their parts.
Ebay is much cheaper........with one exception, sensors...for the most part...bad stuff.
Congratulations and excellent work!
If you listen to music in it at all, you could do so much better then the stock Blows speakers. Even just changing the front center speaker and front door speakers, then working with the built in equalization on the head unit yields something at least listenable.
Reactions: mckay99
Wish I could be as lucky! I had an airbag go out at 50,000 miles, replaced struts at 60,000 miles. Now just under 100,000 miles on my 2013 and there are major rust bubbles on the right rear fender, service airbag soon light just came on, and front evaporative cooler needs to be replaced. Engine runs great though.
1 - 17 of 17 Posts
