2020 Traverse Transmission oil level check
4598 Views 3 Replies 4 Participants Last post by  Ed999
4
Hi guys,
I have 2020 Traverse. And I was wondering which method I should use to correctly level Transmission oil(Dexron VI). I've just drained and filled the tranny oil with engine running at idle and asked my wife to shift back and forth from P thru D.
I then closed the fill plug until the fluid sips out a drop or two. But when I shut the engine down quite amount of fluid drained out. I'd say about a quart or so.
I searched google, youtube you name it. But no perfect answer could be found for the **** "Sealed transmission" and more specifically "GM's 9 speed sealed transmission".
So, I drove about 15 mins let it cool off just a bit. Shut the engine down opened the fill plug it bleeds out the fluid again. At this very moment I think it is overfill but when I turn the engine back on it spills out no more. So I'm completely lost which rhythm I should dance to.
Need help here.
Many thanks!
Automotive lighting Hood Automotive tire Automotive design Motor vehicle
Eye Eyelash Wood Musical instrument Snout
Automotive lighting Automotive tire Hood Motor vehicle Automotive design
Tableware Drinkware Liquid Coffee cup Tea
See less See more
Fluid is checked warm and running at the level plugs.
Next time you service it just measure what comes out and put the same amount back in, so you are not fighting with those level plugs and getting the vehicle level. As long as there are no leaks in the trans. that method works fine.
I've done many previous GM none dipstick transaxles this way with 200k mile sucess.
Reactions: 1
The level is correct when the fluid is fully warmed up and the engine is running at idle. This is when you should see slight drip from the check hole. In my experience the check temperature is only achieved after extensive idle. See this link for the full gm procedure.
Reactions: 1
NEVER shut off the engine with the side check plug open. Ask me how I know.....
  • Haha
Reactions: 3
