121 - 133 of 133 Posts
Plan on doing this tomorrow, then again in maybe 1000 miles just to get as much new full synthetic fluid in as possible. I ordered the plug and will swap that out at the second change. Figure it can only help.
One note, the service manual says to have the car on a level lift. That is not equal to wheels on level ground because the rear is up a bit. Maybe it's nitpicking but I lifted the front a bit until level to make sure I get the oil level correct.
Quick update. I took the car for a short drive and things are good. Mine never had the shudder to begin and gear changes are smooth, now they are just a bit quicker while still being smooth. I'll still do a second change in maybe a month or so, whenever I get a free weekend. I'm still pissed that there isn't a simple dip stick on this transmission. It's also frustrating how hot it needs to be for proper level. My Outback is the same procedure but the temp is lower so you don't have to drive around for half an hour before checking.
Discussion Starter #127
If you heat 6 quarts of ATF up to 150 degrees on the stove and measure the volume, and then bump it up to 200 degrees and remeasure.. the volume is prolly' within a 1% difference.
Regarding fluid level, the insides of a transmission is a very dynamic place. G loads from acceleration , braking, cornering and bumps has the fluid sloshing all over the place.
You should try to get the level spot on... but if you dont, I doubt its really a concern.
There is no "Hot Check" at the GM factory. They build the tranny, dump in the fluid.... and roll.
I personally detest these fluid fill procedures that require exacting temperatures. It's such a scientific requirement that can't be replicated by normal people maintaining there cars.
I measure what comes out, start maybe 1/2 qt low from that and try my best to replicate the factory check procedure. It's so different vehicle to vehicle so this is why I try to stay close to what came out assuming it was filled properly at the factory or by the last person who did that work.
Reactions: AlisoBob
I found that the Chevy was fairly static once I got to the temp range and I think that's because the temp isn't going up much at idle in park. My 2012 Outback CVT is way harder from that standpoint because the temp to check is about 100 degF. If you pull the level plug on the Outback at 95 degrees the fluid will start to just dribble out but the temp is rising quickly and more will come out with every degree. It never really goes to a drip like on the Traverse. If you set it just below 100 degrees but check it just above, some will come out and it will look to be a bit over. The Outback is also really sensitive to being level in the longitudinal and transverse. I'm not sure on the Traverse since I used a 4 foot level before starting.
Thanks AlisoBob for the guide on how to change this - never thought it would be that easy. My 2020 has 2,200 miles and replaced with 6 quarts of Valvoline Dex6 and the magnetic plug. I swear it might be imagining things but when I took it out for a test drive it was shifting like butter.
The only issue is I couldn't find the side plug so i removed about 5.75 quarts (sitting on ramps because there was no way I was fitting under to find the drain plug). I replaced with 6 qts and planned on pulling the side plug but could not find it for the life of me. I looked all over the trans and took off the tire well trim pieces and could not see the same screw as your pictures. I'm don't think i'm that blind?
Discussion Starter #132
With the left front tire removed..... it's very visible.
9490
9491
