81 - 100 of 123 Posts
Discussion Starter #81
I got some photo's for you guys...... Didn't snap a photo of the fluid as it was still cherry red. First is the magnet, pulled after only 1600 miles. Some small debris...... and a big steel sliver!
9099
Here's a paper towel, after I wiped the magnet clean..... the snail track is the usual debris you find on these magnets, the sliver is to the right.
9100
The filter inside the transmission is installed at build. There is no practical way to service it. As the debris packs the filter media, it gets restrictive. The more restriction, the less oil it can flow and the transmissions performance will suffer.
On the Allison transmission, there is a bypass built into the filter. The Green circle is the normal flowpath for the fluid. Should the filter clog, the bypass opens where the Red circle is . The idea is non filtered oil flow is better than no oil flow. As you can imagine, once the bypass opens, transmission life decreases dramatically. As the Traverse filter is not serviceable. I'm sure it has similar construction.
9101
While the magnetic drainplug will not catch friction material or non ferrous bits, its at least an attempt at keeping the Traverse internal filter as clean as we can, for as long as we can.
The Blue Label M1 is in my 2020. Behaves like Dex VI No surprizes....
When I swapped out the fluid, I pulled the rear tires up onto 2X4's to level it better. I also made lunch while it was draining. The result was the full 6 quarts being drained. (I guess leveling the car should be more of a priority)
So there you have it.... at only 1600 miles,the magnetic drainplug has proven worthwhile.....,
Discussion Starter #82
In case you're wondering where such a big sliver could have come from, unlike transmissions the FWD transaxles also contain the ring and pinion gears, which are quite large. In some transaxles they run in a separate oil bath, but in ours they run in the same ATF the transmission uses. There is some sizeable metal, slinging around in there! Even more reason to service it periodically.
9105
9106
deleted
Well I joined the club today. 2019 AWD w/trailering package, 7300 miles.
Drained out 5 qt original fluid, was a bit darker than the new stuff (but not bad).
Replaced standard plug with the magnetic one mentioned in this thread and refilled with 5 qts of the Valvoline DEX VI.
Will probably repeat this process at the 10K mark.
Thanks G. Frog !
Also a little late in thanking you for the LED fog-light upgrade tutorial - did that upgrade about 8 months ago. Your how-to photos were priceless
First transmission service on my 2019 AWD High Country @ 5120 miles. Fluid just slightly discolored in the attached pic, old fluid on the left. Drained out a couple ounces over six quarts, refilled with six and barely a drop or two out of the side plug, so had to add a bit more. Also installed a new magnetic drain plug. OK, time to laugh, but a warning to those who have not done a trans service with a side checking plug - DO NOT STOP THE ENGINE WITHOUT FIRST REINSTALLING THE SIDE PLUG ! You'll have quite a nice little expensive red puddle underneath if you do. Thanks for this thread, very helpful !!
Discussion Starter #88
First transmission service on my 2019 AWD High Country.........DO NOT STOP THE ENGINE WITHOUT FIRST REINSTALLING THE SIDE PLUG !
Dont forget about the TX case, and Rear Diff.
Yes, excellent advise. Do not shut it off with the side plug out!
Discussion Starter #91 (Edited)
If your rear diff looks like this, it would be wise to service it, drive it around for 10 minutes and service it again. The cost for that 2nd quart , will be money well spent.
Great tips and video on the transfer case & rear diff. change. Have to put it up on a lift. It was a stretch (literally) doing the transmission on level ground. That side plug is a tough reach!
Here's how to service the new 9 speed transmission. The wifey's Traverse just hit 2k miles, so lets take a look as see how it's doing. If you can change your own oil, you can do this!! The dealer charges a ton of money to do it, and putting it off could cost you a transmission... so lets get to it! The reason I'm doing it so early is to get the factory oil out, look for any debris, and to install a magnetic drainplug. These transmissions have a non servicable filter.... how dumb! The Allison 1000 in my Duramax trucks has a small spin on, much like a engine oil filter. Why the new 9 speed does not is beyond my thinking. This is the Allison filter...
First, find a good level spot. Most garage floors are level enough. Start by draining the old fluid.... you need a drainpan and 11mm or 7-16ths socket. Let it drain all the way out. This could take 10 minutes or so.
Next, replace the stock drainplug with the Gold Plug. It's not like a cheapo you get a Autozone. This thing is strong!
View attachment 8928 View attachment 8929
It screws in with a 10mm socket . I got mine from Amazon.
There is allot of metal slinging around is this transmission, including the ring and pinion gear. Some FWD transmissions have a separate "Final Drive" full of gear oil for the ring and pinion... not this one. You want any debris to gather on the magnet, rather than plug up the filter.
Then, take the old oil and pour it into something to measure the volume. Here it is sitting in the drain pan. For only having 2k miles on it it's already turning dark and a has a bit of a stink to it.Healthy atf is cherry red... this is more like dark cherry..
View attachment 8931 .
Here it is being measured.You can see how dark it is. It measured out a 5.5 quarts exactly.
Next , pop off the engine cover and remove the fill plug and shove the funnel in.You need a T30 Torx driver to get one bolt out, then the cover pops right off. This long funnel is available at any auto supply store.
View attachment 8933 View attachment 8934
Dump in 6 quarts of DEX VI ATF. I like Valvoline Synthetic . But wait!! Only 5.5 quarts came out. WTF? Well. You can make a choice here. You can put 5.5 quarts in and call it a day, or you can put in the full 6 quarts and set the fluid level... and here's how.
Start it up and let it run for a bit. Let the engine fan come on a few times, so you know it's at full operation temp. Then pull out the "Level" plug WHILE IT'S RUNNING!. It lives behind the left front tire. If you added 6 quarts, then .5 quarts should come out and then it will slowly drip. Reinstall the "Level" plug now. This is what I did. I collected the oil that came out and it was exactly .5 quarts.... so either method works fine.
Then, go for a test drive and look for leaks. I plan to do this again at 5000 miles, then every 30k miles afterwords.
I keep my vehicles for 200k miles.... and regardless of brand or size I do this to every single one..... and I've never replaced a trans in any of them. It's very cheap insurance. The 6 quarts of ATF and the gold plug was $60 and a hour of time. If you have any questions.... ask away. YOU CAN DO THIS!!!
Thank you for the excellent pics and procedure. Just performed this procedure today at 21,000 miles. Had no idea the fluid would be so dirty. Again, most appreciated! 2018 Traverse LT FWD, 3.6L
9139
9140
9141
UPDATE: As I posted in another thread, my Traverse is back in the dealership's service department; the shuddering diminished after they replaced fluid with Mobil 1 LV ATF HP with anti-shudder additives and seemed to go away after approximately 200 miles of driving (as directed by TSB.) However, we now have approximately 1500 miles since the fluid change and the shuddering is coming back. It's not as severe or as frequent as it was previously, but just enough to remind us that it's still there. Service manager stated it will require some driving on their part in order to duplicate, then they will pull transmission and most likely change the torque converter. They've had it four days; about time for me to call for a status update. For my peace of mind, I would like to see them do a Torque Converter replace, but I am willing to give them opportunity to follow their prescribed procedures. I am going to change fluid again at about 12-15,000 mile point, however.
Thanks AlisoBob. I'm confident they will make good in their repairs. They have a good technical staff/team and an outstanding reputation. Service manager commented to me that they had a similar Traverse situation a couple weeks ago that they resolved with TC replacement. They aren't averse to taking things through the ultimate repair requirement.
If only you lived closer to me. Unfortunately EVERY deal I have personally worked with in my area has been horrible.
Great post on servicing the Traverse 9 speed tranny. Please go to Rock Auto and select the transmission filter listed as the ACDelco TF 925. (Look at picture by clicking on "Info".) Where is it located on the transmission?? Inside or outside. My dealer's 9 speed transmission "expert" just gave me I don't know look (?). It would appear to be an external part. My Traverse is a 2020 (Premier), FWD and has been in my driveway for a week. The dealer had to go to FL to get it.
Right now the only thing I want to add is a oil catch can on the vent hose from the PCV (orfice since it contains no valve). I've got a compound guage (Vacuum and pressure) coming. I may tap it on top of the dipstick tube so I can see if there is a pressure build up inside the engine from unvented piston blow by. Just before becoming someones else's problem my 2011 GMC Acadia (30K miles) went through 4 (as in four) qts. of oil in four weeks. By all accounts of reverse engineering it was from a plugged up PVC system and pushing oil past the oil control rings on the pistons. Show us how!
Great link to 540RATBLOG.wordpress.com on oil.
More, more please! Great reading!
