Hey Everyone,
Bran new to the forum. I didn't realize i had an account so this is my first post. I recently had my traverse brought in to the dealership to perform the 50K tune up. They replaced the air fileter, cain filter, they drained and replaced the transmission fluid, performed a brake flush and crankcase service. Its been over a month now and i recently had the check engine light populate the other week. Had Ons star perform the diagnostics while i was on the road. I was told the code returned was P0420. I figured it was something to do with the gas tank pressure as it occurred frequently on my 08' Cadillac CTS.
A few days later and of course, it seemed to clear itself, then a few days ago it reappeared. Then went away again earlier this morning. I decided to use my OBD scanner and it came to return the same P0420 code. I then went to check the freeze frame data and came across the following readings. Would anyone be able to elaborate more on this data? Im almost certain it can be an O2 Censor but just was curious to what all this data translates to. Any information is greatly appreciated.
DTCFRZF ---------: P0420
FUEALSYS1 ------: OL-Drive
FUEALSYS2 ------: N/A
LOAD_PCT(%) ----: 23.5
EXT (°C) -----------: 82
SHRTFT1(%) ------: 0.0
LONGFT1(%) ------: -10.9
SHRTFT2(%) ------: 0.0
LONGFT2(%) ------: -11.7
FRP (KPa) ----------: 399
MAP (KPa) ---------: 26
RPM (/min) --------: 1119
VSS (km/h) --------: 62
SPARKADV (°) -----: -3
IAT (°C) -------------: 23
MAF (g/s) -----------: 5.33
TP (%) --------------: 17.6
02B1S1 (V) ---------: 0.000
SHRTFTB1S1 (%) -: 0.0
O2B1S2 (V) --------: 0.225
SHRTFTB3S1 (%) -: 0.0
02B3S2 (V) ---------: 0.870
RUNTM (sec) -------: 289
FRP (KPa) -----------: 3400.0
EVAP_PCT (%) -----: 0.0
FLI (%) --------------: 91.0
WARM_UPS --------: 255
CLR_DIST (km) -----: 65535
EVAP_VP (Pa) -------: 25.00
BARO (KPa) ---------: 100
CATEMP11 (°C) -----: 771.00
CATEMP21 (°C) -----: 771.00
VPWP (V) ------------: 14.583
LOAD_ABS (%) ------: 15.1
EQ_RAT --------------: 0.999
TP_R (%) -------------: 7.5
AAT (°C) --------------: 11
TP_B (%) -------------: 17.6
APP_D (%) -----------: 19.6
APP_E (%) -----------: 9.8
TAC_PCT (%) --------: 10.6
