Here is a really good Offset calculator that will help you make the right choices.hi
i have 2018 chevrolet traverse lt cloth fwd.
Can you or someone please guide and advise me on wheel measurements so that i buy the correct one. also if there are other better options to buy from than pmctire.
thanks
https://www.wheel-size.com/calc/
Wheels-size.com's home page also has a tools for wheels and tires for specific vehicles.
Our 2018 Traverses have wheel offsets of +50 (written as ET50).
It is very important for any replacement wheels to have Offset that closely match the our wheel offset of +50.
Offsets of less than +50 will result in wheels and tires extending outwards and may rub on the fenders when you hit a bump; and that is just one small issue. The changes in steering geometry will cause weird handling and extra wear on steering components.
Offsets greater than +50 will move the wheel closer to the suspension and brakes. Again causing potential problems.
To learn more about wheel offset and other steering geometry details check the Tire Rack website here: https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=101
Good luck.
