My 2017 Traverse LS has a random no start issue. Put the key in the ignition and turn it, absolutely nothing. It's almost as if you have to apply excessive force when turning the key to get it to start. I can't see a worn ignition lock cylinder already being the culprit.
Also, it will occasionally die right after starting and then this will be an issue. It has shut down backing out of sparking space, then will start and be fine. This is completely random behavior with no pattern. It'll go months in-between without an issue
Any ideas?.
Any ideas?.
