1 - 2 of 2 Posts
Hello, my google skills fail me. Today our 27k mile Traverse popped a non flashing PO302 Cylinder2 misfire code and had it stored twice by the time I was able to pull it.
I wanted to look for critter damage but not knowing which one cylinder2 is made it more of a general search. My google skills fail me, which is it?
Also, my plan is to clear the code apparently by unplugging the battery for a bit then see if it happens again. Either way we'll tell the dealership the story in the morning.
On my old enough to buy its own alcohol Lincoln I'd pull the coil over, soak up the oil in the plug valley, at least pull and clean the plug then reinstall. If the code came back I'd change the whatever coil over (that has fixed misfire errors twice for me). Anything different on this new thing while I see what our dealership is worth?
Cylinder 2 is the front Left. While looking at the engine cylinders are 1,3,5 in the back (left to right) then 2,4,6 in the front.
1,3,5
2,4,6
==== <- Radiator
1 - 2 of 2 Posts
