Anyone have specs for the rear ride height? I have put on new shocks to control a bouncy ride but it seems to bottom out to easy. I can only fit one finger between the bump stops in the rear which seems way off. Beginning to think my springs are toast.
On my 2015 LTZ I have just a little more than my finger thickness between the bump stops. From the ground to the level area of the rear bumper by the rear hatch opener, it is 26 inches.
Suggest you post year and trim level.
[/QUOTEth
It says it on the title thanks sally
Same here with the finger width. Seems odd to me it's that close. The ride in the rear seems to bottom out to easy. And have new shocks. Looked at some dealerships traverses and they sit higher in the rear. May just end up replacing the spring with stiffer moog ones. Maby upgrade from Monroe shocks to Bilstein gas shocks also.
