Hi i have a 2012 chevy traverse with what appears to be having torque converter engagement and disengagement problems
from 4th gear on. it has a flair up on the 4-5 shift , also a faster than normal 5-6 shift with an occasional chug depending on throttle position .
At 60mph the tac fluctuates in lock up 1600 to 18-1900 RPM bounce .
I can command the TCC solenoid on with scan tool, and at 55 , 60 ,65 it doesnt appear to have torque converter slip.
It has no engine DTC’S , NO MISFIRES , NO Transmision Dtc’s , I’ve changed the dex6 ATF 4 times now which did improve the shift delay leading up to the above.
Valve body ? THCM?
Valve body ? THCM?
