1 - 2 of 2 Posts
Does anyone have a good place to purchase the plastic skirting around the bottom of the front seats? Are they difficult to replace?
Not sure where to buy one, but check ebay or local salvage yards as it shouldn't be to hard to find one. Not that difficult to replace, but you need to remove the side trim first as they will come off together as the front skirt is held in by side/slide in clips to the side trim and it's near impossible to separate the two with them on the seat. Slide the seat belt trim up and you'll find some screws under it and then pop out the switch panel near the rear (not the front) and then slide it rearward as there is a slide clip you'll break if you try and pop the front first. Here's a video that will help and note the front skirt is just pulled straight out and held in by two push clips and you'll need to pull hard to get it out.
1 - 2 of 2 Posts
