AC blows cold with no problem but started to notice the rear AC barely blows out of the vents and the my kids started asking me to to turn the ac on full blast because they were hot and sweating. And then I noticed that it sounded like the ac was on full blast inside the rear side panel so after some internet research I ended up finding a few you tube videos where others had the same problem with air barely blowing out of vents and after taking the panel down they found that the tube had started to come off so the air was blowing into the side panel instead full force out the vents. So I had a mechanic take the side panel off and seem to be nothing that was loose and became disconnected so they thought maybe the actuator was bad so changed that out $240 later and that wasn’t even the problem so now I’m back to beginning of trying to figure out why the rear ac is barely coming out of vents without having to go through everything costing me $$$$$ which I don’t have . So if someone can please help me figure this out
