I just got a 2011 Traverse LTZ & am anxious to install some electronic gizmos -- RADAR detector, a
separate GPS (yes, I have the navigation package, but want to hook up my own GPS so I get
altitude info, the hundreds of waypoints already stored, and so I can pop it out of the holder/charger
& use it outside the car), etc. All of the above are low current-draw items & my thought is I can
route power cable to the main electrical terminal in the engine compartment via the firewall, and then
hook up my gadgets to a Powerworks power distribution terminal I'll mount under the dash or inside
the front center hump where the shifter is.
I have experience doing the above sort of thing with older vehicles, and other than trying to find some free space
to mount the items, I'm not anticipating any problems.
HOWEVER, I also have some ham radio gear that will be mounted somewhere around the back of the vehicle, either
under the 3rd-row bench seat or ?? and would like to power that equipment directly from the battery.
I've been told that the car's battery is located somewhere in or under the passenger compartment of the car. The salesman
said it's under the third-row seat, another posting here indicated it's just behind the front passenger seat, but that location
may not have been for a 2011 model.
Where exactly is the battery on a 2011 Traverse LTZ, and what is the easiest way to access it?
If the battery is sealed (to prevent fumes, etc. entering the passenger compartment), is there an
electrical junction/fuse box or other sort of power terminal near the battery that I could easily access?
I'm wanting to hook this gear up to the battery because the radio equipment will be mounted towards the
rear of the vehicle where I believe the battery is & that'll mean less amount of wiring I'd need to hide behind
moldings, etc.
I am very annoyed that the owner's manual doesn't have any info about the battery location or how
to access it!
I'll also be hooking up a couple antennas to the vehicle. If there's another ham radio operator or
anyone else out there with a late-model Traverse that has experience mounting antennas, powering
various electronic devices & routing all the cables so they're out of sight, etc. I'd love to hear from you
& learn from your experience before I start hooking things up.
I paid cash for my Traverse & am just about broke after doing so, so I am NOT anxious to start
hacking-up the vehicle to mount all my radio stuff, but I miss not having all my electronic toys & tools.
moldings, etc.
to access it!
