Havc questions; took out the blend door actuator as the front driver's side only would blow hot, hot air when in a/c mode. New part coming Tomorrow. So that temporarily let cold air blow through all vents till later that evening the cabin all of a sudden started to blow hot air. So turned off rear air still had cold in front. Get home vehicle sat unused till 5 days later. Turned car on hot air still blew in back and warm air in front then went hot. Put a gauge on to check pressure of freon there is freon. Good. compressor was running a few minutes then turned off. Remind you the blend door actuator part is still not in there yet because you had to order.once we get the new cart will this fix the situation going on or is there something else somebody can advise on troubleshooting where do we begin to look to figure this out thank you Sherry
