I have been doing some research Between the Traverse 3.6 and the camaro 3.6 and the only difference between the two engines are the intake manifolds and throttle bodies. They both use the same fuel pump,injectors,cylinder heads,camshafts,pistons,and pretty much everything else.
I wonder if swapping the camaro intake manifold and throttle body to the traverse would be possible? if so that would obviously add more power to the Traverse engine which would mean better fuel economy.
With the Traverse weighing in at 5,066 pounds, any extra power that helps the engine breath easier would diffently be helpful to it's fuel economy.
