1 - 2 of 2 Posts
I have a 2010 chevy traverse and it recently got diagnosed with a bad downstream o2 sensor and later on the engine would shut down got a scanner and now it has misfire in ignition coils 2,4 and 6, changed the coils but still the engine dies at a complete stop and the codes for the coils still comes up, what can it be?
What codes are you getting? The codes that tie to the performance of the catalytic converter can be interpreted as O2 sensors. The O2 sensors measure the difference in the exhaust between two points in the exhaust system. If the values between the two sensors are the same the check engine light is fired. If the catalytic converter is not doing its job the O2 sensors are reporting no change in the exhaust correctly. To address the catalytic converter needs replaced. A clogged converter may cause a stall when idling. A failed converter is somewhat common but a clogged is not but possible.
1 - 2 of 2 Posts
