HTML:
[b] 2009 CHEVROLET TRAVERSE SPECIFICATIONS [/b]</p>
[b]Overview [/b]</p>
<table border="1" cellpadding="0" cellspacing="0">
<tr>
<td width="211" valign="top">
Models: </p></td>
<td width="348" valign="top">
Chevrolet Traverse </p></td>
</tr>
<tr>
Body style / driveline: </p></td>
crossover SUV / front-engine; front-wheel drive and all-wheel drive </p></td>
</tr>
<tr>
Construction: </p></td>
body-frame integral </p></td>
</tr>
<tr>
EPA vehicle class: </p></td>
sport utility vehicle </p></td>
</tr>
<tr>
Manufacturing location: </p></td>
Spring Hill , Tenn. </p></td>
</tr>
<tr>
Key competitors: </p></td>
Toyota Highlander; Honda Pilot; Ford Explorer </p></td>
</tr>
</table>
[b] Engine [/b]</p>
<tr>
Type: </p></td>
3.6L V-6 </p></td>
</tr>
<tr>
Displacement (cu in / cc): </p></td>
217 / 3564 </p></td>
</tr>
<tr>
Bore & Stroke (in / mm): </p></td>
3.70 x 3.37 / 94 x 85.6 </p></td>
</tr>
<tr>
Block material: </p></td>
aluminum </p></td>
</tr>
<tr>
Cylinder head material: </p></td>
aluminum </p></td>
</tr>
<tr>
Valvetrain: </p></td>
DOHC; 4 valves per cylinder; variable valve timing </p></td>
</tr>
<tr>
Fuel delivery: </p></td>
direct, high-pressure fuel injection </p></td>
</tr>
<tr>
Compression ratio: </p></td>
11.4:1 </p></td>
</tr>
<tr>
Horsepower (hp / kW): </p></td>
281 / 210 @ 6400 (single exhaust)*
286 / 213 @ 6400 (dual exhaust)* </p>
</td>
</tr>
<tr>
Torque (lb-ft / Nm): </p></td>
253 / 343 @ 5500 (single exhaust)*
255 / 345 @ 5500 (dual exhaust)* </p>
</td>
</tr>
<tr>
Recommended fuel: </p></td>
regular unleaded </p></td>
</tr>
<tr>
Max. engine rpm (fuel cutoff): </p></td>
7000 rpm </p></td>
</tr>
<tr>
Emissions controls: </p></td>
dual close-coupled converters; 2 pre- and 2-post oxygen sensors </p></td>
</tr>
<tr>
Estimated fuel economy: </p></td>
TBD </p></td>
</tr>
</table>
[b] Transmission[/b][b] & Power Take Off Unit (PTU)[/b][b][/b]</p>
<tr>
Manufacturer: </p></td>
GM Powertrain </p></td>
</tr>
<tr>
Type: </p></td>
Hydra-Matic 6T75 6-speed FWD/AWD automatic transmission </p></td>
</tr>
<tr>
Gear Ratio (:1) </p></td>
</p></td>
</tr>
<tr>
First: </p></td>
4.48 </p></td>
</tr>
<tr>
Second: </p></td>
2.87 </p></td>
</tr>
<tr>
Third: </p></td>
1.80 </p></td>
</tr>
<tr>
Fourth: </p></td>
1.47 </p></td>
</tr>
<tr>
Fifth: </p></td>
1.0 </p></td>
</tr>
<tr>
Sixth: </p></td>
0.742 </p></td>
</tr>
<tr>
Reverse: </p></td>
2.88 </p></td>
</tr>
<tr>
Final drive ratio: </p></td>
3.16 (FWD / AWD) 2.73 (FWD) </p></td>
</tr>
</table>
[b] Chassis/Suspension [/b]</p>
<tr>
Front: </p></td>
coil-over strut; direct acting stabilizer bar; full perimeter isolated cradle </p></td>
</tr>
<tr>
Rear: </p></td>
linked H-arm independent suspension; coil springs with twin-tube shock absorbers mounted on isolated sub-frame </p></td>
</tr>
<tr>
Steering type: </p></td>
hydraulic rack-and-pinion; straight ratio and variable effort </p></td>
</tr>
<tr>
Steering ratio: </p></td>
16.1 </p></td>
</tr>
<tr>
Steer wheel turns, lock-to-lock: </p></td>
2.89 </p></td>
</tr>
<tr>
Turning circle, curb-to-curb (ft / m): </p></td>
40.4 / 12.3 </p></td>
</tr>
</table>
[b] Brakes [/b]</p>
<tr>
Type: </p></td>
4-wheel disc </p></td>
</tr>
<tr>
Rotor diameter (in / mm): </p></td>
front: 12.8 x 1.1 / 325 x 29, ventilated
rear: 13 x 0.8 / 331 x 20, ventilated </p>
</td>
</tr>
<tr>
Anti-lock braking system (ABS): </p></td>
Bosch 8.0 Chassis Controls: ABS / ETC / ESC w/rollover mitigation </p></td>
</tr>
</table>
Wheels/Tires </p>
<tr>
Wheel size and type: </p></td>
17 x 7-in; steel
18 x 7.5-in; cast aluminum
20 x 8-in; Ultra-Bright cast aluminum </p>
</td>
</tr>
<tr>
Tire size and type: </p></td>
P245/70R17 ALS blackwall
P255/65R18 ALS blackwall
P255/55R20 AL3 blackwall </p>
</td>
</tr>
</table>
[b] Dimensions
[/b][b]Exterior [/b]</p>
<tr>
Wheelbase (in / mm): </p></td>
118.9 / 3019 </p></td>
</tr>
<tr>
Overall length (in / mm): </p></td>
205 / 5206 </p></td>
</tr>
<tr>
Overall width (in / mm): </p></td>
78.4 / 1991 </p></td>
</tr>
<tr>
Overall height (in / mm): </p></td>
72.8 / 1846 (w/roof rails); 69.7 / 1770 (w/o roof rails) </p></td>
</tr>
<tr>
Track </p></td>
</p></td>
</tr>
<tr>
Front (in / mm): </p></td>
67.8 / 1721 </p></td>
</tr>
<tr>
Rear (in / mm): </p></td>
67.4 / 1711 </p></td>
</tr>
<tr>
Curb weight (lb / kg): </p></td>
4720 / 2141 (FWD)
4925 / 2234 (AWD) </p>
</td>
</tr>
<tr>
Min. ground clearance (in / mm): </p></td>
7.2 / 183 (FWD and AWD) </p></td>
</tr>
</table>
[b] Interior [/b]</p>
<tr>
<td width="271" valign="top">
Seating capacity: </p></td>
<td width="288" valign="top">
7 or 8 </p></td>
</tr>
<tr>
Headroom </p></td>
</p></td>
</tr>
<tr>
First row (in /mm): </p></td>
40.4 / 10264 (w/o sunroof); 38.6 / 979 (w/ sunroof) </p></td>
</tr>
<tr>
Second row (in / mm): </p></td>
39.4 / 1000 (w/o sunroof); 38.73 / 983 (w/ sunroof) </p></td>
</tr>
<tr>
Third row (in / mm): </p></td>
37.8 / 960 (w/o sunroof); 38.1 / 968 (w/ sunroof) </p></td>
</tr>
<tr>
Legroom </p></td>
</p></td>
</tr>
<tr>
First row (in / mm): </p></td>
41.3 / 1049 </p></td>
</tr>
<tr>
36.8 / 937 </p></td>
</tr>
<tr>
37.8 / 690 </p></td>
</tr>
<tr>
Shoulder room </p></td>
</p></td>
</tr>
<tr>
62 / 1575 </p></td>
</tr>
<tr>
61.3 / 1558 </p></td>
</tr>
<tr>
57.6 / 1463 </p></td>
</tr>
<tr>
Hip room </p></td>
</p></td>
</tr>
<tr>
59.1 / 1502 </p></td>
</tr>
<tr>
57.8 / 1467 </p></td>
</tr>
<tr>
48.3 / 1227 </p></td>
</tr>
<tr>
Cargo volume </p></td>
</p></td>
</tr>
<tr>
Second and third row folded (cu ft / L): </p></td>
117.9 / 3340 </p></td>
</tr>
<tr>
Second row up, third row folded (cu ft / L): </p></td>
68.3 / 1934 </p></td>
</tr>
<tr>
Behind third row (cu ft / L): </p></td>
26.1 / 739 </p></td>
</tr>
</table>
[b] Capacities [/b]</p>
<tr>
Fuel tank (gal / L): </p></td>
22.0 / 83.3 </p></td>
</tr>
<tr>
Engine oil (qt / L): </p></td>
5.5 / 5.2 </p></td>
</tr>
<tr>
Transmission fluid (qt / L): </p></td>
9.5 / 9.0 (Dexron VI only) </p></td>
</tr>
<tr>
Cooling system (qt / L): </p></td>
11.8 / 11.18 </p></td>
</tr>
<tr>
Max towing capacity (lb / kg): </p></td>
4500 / 2041 </p></td>
</tr>
<tr>
GCWR (lb / kg): </p></td>
9500 / 4309 (FWD)
9700 / 4400 (AWD) </p>
</td>
</tr>
<tr>
GVWR (lb / kg): </p></td>
6459 / 2930 </p></td>
</tr>
</table>
* Preliminary, pending SAE certification. </p>
Note: Information shown is current at time of publication.
