2009 Chevy traverse traction control issue start moving all sudden brakes start grabbing traction control light comes on after 1 or 2 min brakes unlock traction control goes off turning wheel to the right befor taking off turns traction control off gets normal start turning off traction control button does not work still same brake issue brake light does not go off when brakes are grabbing
Get your codes read. All of them not just P codes but also the U, C and B codes.
Probably there's a few in the ABS codes.
Knowing what codes there are is step one to a repair in todays computers on tires.
You need to get the codes. More than likely one of your hubs is bad, possibly speed sensors. The codes will let you know exactly which one is bad.
