1 - 3 of 3 Posts
So I been having the service stabilitrac reduce engine power happen for about a month now we’ll last night it happened pulled off went to try and restart I’m getting one hard click from starter and that’s it no cranking at all starting acting like it’s it’s trying to crank motor has a slight jerk when attempting to start please help
Some folks have had the Stabilitrack issue traced down to the under hood fuse box being loose. Try tightening the two screws just snug. The starting relay is in there as well. If you suspect a bad relay, you can swap it with another one the same size.
Just an update I attempted to turn the engine over by the crank and low and behold it’s locked up FML ain’t had this **** thing 8 months
1 - 3 of 3 Posts
