April 23, 2017, 11:24:57 PM *
Pages: [1]   Go Down
Author Topic: 2009 coolant leak/water pump recall  (Read 9806 times)
bjl
« on: October 28, 2013, 02:02:01 PM »
Friday I took our 2009 Traverse in for an oil change. Also wanted them to check the water pump. Occasionally I have drips of clean coolant on my garage floor and sometimes need to fill my overflow tank. I to have the letter regarding water pump leakage and the extra warranty on this.
The advisor calls me back and said they ran a pressure check- all was fine (but had to add coolant).  They charged me $50 for the diagnosis. Saturday morning there was a huge puddle of fresh coolant on my garage floor and the tank was almost empty. Never has it l;eaked like this before!
I called this morning, it is going back in tomorrow. So frustrating.
Water pump has to be the issue right?
There is more with this visit-but lets see if they fix the problem.
Thanks,
bjl
« Reply #1 on: October 28, 2013, 02:55:05 PM »
there have been reports from others--
a leak is present here and there... coolant gets low.
then they have it pressure tested-- and it comes back fine..
then it fails big time withing a few days...
Bayner66
Hero Member
« Reply #2 on: October 28, 2013, 02:57:38 PM »
If you constantly have to add coolant you have a problem. The fluid is going somewhere.
On the new puddle on the floor---if the dealer employee filled the overflow tank too full a bunch of fluid could have been pushed out the overflow after you drove it home. The full level on the overflow tank is only about an inch from the bottom of the tank which fools many because you would think it should be at least half way up on the tank.
Bayner66
writing from
The Lone Star State
2014 Acadia SLT2 FWD
« Reply #3 on: October 28, 2013, 03:25:40 PM »
bayner makes an excellent point about the possible overfilling of the reservoir.
bjl
« Reply #4 on: October 28, 2013, 04:01:33 PM »
Yes- I have heard of overfilling. Don't think this is the case though. The tank was almost empty Saturday morning.
I usually just keep an eye on the fluids including coolant. My drips on the floor have been occasional until now. In the past I would only have to add coolant probably every 3 months to the overflow tank. The dripping was always in the same spot (front of the engine- closer to the passenger wheel).
Since I got another warranty note in the mail this month, I wanted it taken care of since I do have symptoms of a leak. I was having regular service done anyway. Did not expect what has happened. I wanted it fixed, not misdiagnosed and spending more time and money. This should have been fixed Friday and I should have been charged nothing. Ugh!
CGIM5804
Full Member
« Reply #5 on: October 28, 2013, 08:14:23 PM »
Make sure they change it and ask for your $50 back.  It is leaking, they should have changed it before you got stuck and had to be towed.
bjl
« Reply #6 on: October 28, 2013, 09:50:42 PM »
Sure will ask for a refund on the $50!
I drove about 10 miles today. Huge puddle under it again! I will need to add coolant before driving to the dealership in the morning.
bjl
medicrxdoc
« Reply #7 on: October 28, 2013, 10:22:42 PM »
Who has the picture of the coolant bottle and the full line being very close to the bottom?  Just want to make sure we are at the proper level.  There isn't a lot in the bottle when at the full level.
« Reply #8 on: October 28, 2013, 10:50:55 PM »
50and unretired had posted a really good pic of the true FULL level mark...
which is way down on the bottle.. many think its the beginning of the line...
YOu have to lean over to see the arrow from the front of car..
bjl
« Reply #9 on: October 30, 2013, 02:22:17 PM »
Just picked up the Traverse at noon today. It was the water pump (no surprise). They did reimburse the money for the diagnostics too.
We will see, hopefully everything is now back to normal. It is raining today so hard to tell.
Thanks to all for your input.
bjl
Chevrolet Customer Svc
View Profile WWW
« Reply #10 on: October 30, 2013, 11:14:19 PM »
bjl
Very happy to hear that your concern has been resolved. Please monitor the operation of your vehicle and don't hesitate to contact us if further concerns arise.
Sincerely,
William R.
Chevrolet Customer Care
