March 26, 2017, 12:58:36 PM *
Pages: [1]   Go Down
Author Topic: Transmission Cap and Dipstick  (Read 10095 times)
0 Members and 2 Guests are viewing this topic.
ngrindle
Newbie
« on: January 29, 2012, 07:33:24 PM »
Ok everyone, sorry if these are stupid questions but I just got a 2011 Traverse this weekend and I'm a little lost when it comes to the tranny dip stick and cap.
1.  I can't find the tranny dip stick anywhere.  Maybe I'm blind but I don't see it.  If someone could post a pic of it or direct me in the right direction that would be very helpful.
2. I found the transmission cap but I can't get it to come off.  All I can do is get it to turn about half a turn each way.  Is this how its supposed to be?  Is there something special that has to be done to get it to come off?  I even tried to push it in and nothing.
Thanks in advance for the help everyone.
screw991le
Full Member
« Reply #1 on: January 29, 2012, 09:01:54 PM »
The trans has no dip stick, just like a manual trans.  Can you post a picture of what "cap" you are trying to turn?
2011 Black Granite Metallic LTZ AWD - Loaded
2008 Liquid Red Pontiac G8 GT - Loaded
AA/78U-Blue Gold
Guest
« Reply #2 on: January 29, 2012, 09:16:03 PM »
The trans has no dipstick??; did GM remove the ability to check the fluid level on the Traverse  Huh?
medicrxdoc
« Reply #3 on: January 29, 2012, 10:09:50 PM »
I believe it takes a special tool to check it.  Filled for life!   BS
« Reply #4 on: January 29, 2012, 10:13:29 PM »
unless something changed with the 2011's...
heres pics of my 2010.
the trans dipstick
and the location of the dipsticks cap- down at the middle of the bottom of pic
I believe its a twist and turn and pull up
Note that my air filter and air tube to the throttle body is removed.
Though you can see and access the trans dipsticks without removing the forementioned items.
in the 1st pic- you can see the tube is still in place but Ive removed the dipstick
jwhjr
Hero Member
« Reply #5 on: January 29, 2012, 10:50:53 PM »
Our 2011 is the same as rbarrios' pictures and the cap comes off the same.
2011 Traverse 1LT AWD
Cyber Grey Metallic
ngrindle
Newbie
« Reply #6 on: January 30, 2012, 05:41:47 AM »
Thanks rbarrios for the pictures, That's the cap I was trying to turn but can't seem to get it off. When I turn it counter clockwise it only goes about half way and stops.  I even tried to push it in to get it to turn further and nothing.  Is your's hard to get out?  Is there a trick when you are turning it to get it to loosen up all the way?  Seems so simple but my darn cap just didn't want to turn after that half turn point.
Quantum
Global Moderator
« Reply #7 on: January 30, 2012, 07:46:29 AM »
The cap only turns 1/2 a turn if I recall correctly.  It's probably just the friction of the gasket that is keeping you from pulling it out.  Turn the cap like you did before, but give it a good pull, it will come out.
2010 Traverse 1LT
Built 3/10 in Lansing, MI
Ontario, Canada
BigBlackTraverse
« Reply #8 on: January 30, 2012, 08:41:17 AM »
Hay how many people know where the Radiator cap is ha ha...
I know, I know....
               All-Star Edition.
GXPWeasel
« Reply #9 on: January 30, 2012, 09:02:50 AM »
Our Traverse's Trans dipstick is the same as Rbarrios has shown here.
I agree with Rbarrios as well. The cap only turns about half a turn, and then just pulls straight out. The gasket has probably stuck to the surface from the factory. It will just take a slight tug to get it off. I would suggest smearing a small amount of the trans fluid or oil on the rubber o-ring on the cap, so that it doesn't stick the the housing agagin.
Greg.
ngrindle
Newbie
« Reply #10 on: January 30, 2012, 09:42:38 AM »
Sure enough, that was it.  Just need a good pull once it was turned.  I feel like an airhead for not figuring that out on my own but I guess thats what these things are for.  Thanks everyone for the help!
screw991le
Full Member
« Reply #11 on: January 30, 2012, 01:42:10 PM »
Thats what I get listening to the dealership.  I know my G8's Trans does not have a dipstick.  So I figured the dealer was not FOS. Oh No
tableclocks
« Reply #12 on: November 20, 2014, 08:09:31 PM »
 mine  is  a  2014,  can I check the transmission fluid the same way?  will it have a dip stick on the cap, or is it just a cap to fill  the  trans,,,thanks
richard
« Reply #13 on: November 20, 2014, 08:11:36 PM »
there is a dipstick on your 2014.
tableclocks
« Reply #14 on: November 20, 2014, 09:20:38 PM »
  thanks,  just  so  I  don't  brake  anything,  will the cap  turn  1/2 turn  or  so  and  pull on  it,   I  am  not  stupid,  I  just  don't  want to  brake  anything,   thanks,,,richard
richard
Quantum
Global Moderator
« Reply #15 on: November 20, 2014, 09:35:04 PM »
Yes, turn it left about 1/2 a turn, the cap will not turn any further, then give it a good solid pull.  It will come out.
2010 Traverse 1LT
Ontario, Canada
Boatwrench
« Reply #16 on: November 20, 2014, 11:50:59 PM »
and this is important.
When reinstalling the dipstick make sure that you place it back in the same position.
There is a white arrow pointer on the cap, it is visible in the previously posted photographs. When installing the arrow should face the L/F tire and when twisted close and installed all the way the arrow should face forward.  You can feel an arrow pointer cast into the transmission, that pointer and the arrow pointer on the dipstick need to line up when the dipstick cap is seated.
Failure to install correctly can result in the pot metal tab at the tip of the dipstick to bend and possibly break off inside the trans. Guess how I know?  A replacement dipstick from the dealer is $24.
No one's right if everybody's wrong.
tableclocks
« Reply #17 on: November 22, 2014, 06:53:56 PM »
                                                            thank  you..........richard
richard
