March 28, 2017, 09:45:12 AM *
News: Check out our new iPhone, Android & Blackberry App! More info
Pages: [1] 2  All   Go Down
Author Topic: 2009 AWD 100k 13mpg??  (Read 938 times)
bmcmahon42
« on: February 15, 2017, 07:23:10 PM »
I've take proper care of my kid taxi but my mileage has never been great. Best I've seen is 17mpg and not expecting much more. I reset the DIC counters on every fill up and I'm averaging around 13mpg and sometimes lower. Ideas?
Pending maintenance:
Plugs
Transmission Fluid Change
Clean air intake valve..got some pooled oil..spray some intake cleaner.
Anything else?
Toddzilla67
Hero Member
« Reply #1 on: February 15, 2017, 08:45:36 PM »
I think an intake cleaning, new plugs, and a new air filter will probably help your MPG the most at this point.  If you're not already doing it, adding a fuel system cleaner at a consistent interval will help things out, too.  There are plenty of people here that use only Tier One fuel and add Techron (or similar) at every oil change.  I use only Tier One fuel and add one can of BG44K once a year and I've not had any issues.  Your mileage (and the opinions of others) may vary.
We just did 100K maintenance on our 2010 back in November/December.  This included new plugs, intake cleaning service (1st time), transmission flush (second time), and coolant service done at the dealer.  We were seeing between 14.5 and 15 MPG around town, but high temps had been around freezing and lows were below zero.  After the service, MPG was between 16.0 and 16.5 MPG around town (back to where it had been in colder weather) and we averaged over 21 MPG on our 1600+ mile Thanksgiving round trip--I think the intake clean and plugs were probably the keys to that improvement.  That trip was with a fully loaded vehicle, lots of mountain driving, some in-town driving mixed in, and fairly cold temps.
I also did an oil change, air filter change, transfer case/rear differential fluid change (2nd time), front brakes (1st time), and serpentine belt (1st time) before we left on our trip, then replaced the factory struts/shocks after Christmas.
100K maintenance can be expensive, but worth it if you're keeping the vehicle for an extended amount of time.
2010 Traverse LTZ AWD
Born 11/09
Silver Ice Metallic, Titanium Leather
DVD, Nav, Sunroof, Towing
Just drive it.
« Reply #2 on: February 15, 2017, 10:06:54 PM »
my 100,000 mile service....
http://www.traverseforum.com/index.php?topic=16321.0
how to trans fluid
http://www.traverseforum.com/index.php?topic=2900.0
how to serpentine belt
http://www.traverseforum.com/index.php?topic=9938.0
how to air filter
http://www.traverseforum.com/index.php?topic=1620.0
how to throttle body- clean
http://www.traverseforum.com/index.php?topic=1621.0
whipster
Full Member
« Reply #3 on: February 16, 2017, 01:20:41 PM »
Just wanted to add to these great posts. Cleaning the Mass Airflow Sensor would be a good idea. You can get a can of CRC 05110 MAF cleaner and clean that yourself. Pretty easy, just take it off the air tube and spray all around the inside and let dry, reassemble. Dirt on the sensor can alter the fuel mixture to a degree.
2012 Traverse LT2
Toddzilla67
Hero Member
« Reply #4 on: February 16, 2017, 02:27:53 PM »
Yep, did that as well.  Too much for this older mind to keep track of.
Born 11/09
Just drive it.
« Reply #5 on: February 16, 2017, 06:17:28 PM »
the mass air flow sensor is one thing Ive never cleaned..... in any of my cars...
maybe ill do that next oil change.
whipster
Full Member
« Reply #6 on: February 16, 2017, 06:51:15 PM »
A person can look at a few pids and see a difference sometimes. Like the load, grams per second, fuel trims, not sure if the lambda's use hertz(a raw maf reading). Drawing a blank if there's any others, hehe.
I like to use the spray and compressed air a couple times to clean the filament. I think these are internal so you wouldn't see any working parts like the older cars used. Those were just filaments hanging in mid air and easy to see the dirt on them. Just have to get some spray in the holes from different directions the best you can.
2012 Traverse LT2
whipster
Full Member
« Reply #7 on: February 16, 2017, 06:52:20 PM »
Oh, I can relate to that!
2012 Traverse LT2
lookylou
« Reply #8 on: February 16, 2017, 07:28:44 PM »
It's super easy to do on the Lambdas. All you do is unplug the MAF and remove the 2 screws holding it to the air duct connecting the air filter case to the throttle body. Just be careful not to touch anything but the plastic housing of the MAF and you should be fine.
'12 - Silver Ice Metallic - LT1 - FWD
K & N Air Filter
Magnaflow XL Turbo
Weathertech Window Deflectors
Weathertech Bug Deflector
UUI Head Unit (w/USB)
''18 Pirelli Scorpion Verde Plus
bmcmahon42
« Reply #9 on: February 16, 2017, 11:16:36 PM »
Thanks everyone. I'll start with the throttle body clean since I have to take everything off to get to the rear plugs anyways. I picked up some Bosch plugs, intake cleaner, and a gasket. I dumped some Techron Fuel System Cleaner on fill up today as well. Found a fairly detailed video on YT but apparently I can't post links.
whipster
Full Member
« Reply #10 on: February 17, 2017, 06:35:50 AM »
Do not put in Bosch plugs unless you have a Mercedes. If you have a mopar you put in champions, ford takes motocraft. The off brands can be a compromise. Best to put in the factory plugs the engine was engineered with. The factory Delco plugs are made by NGK, arguably the best mfr of plugs. They have Iridium pucks on both ends and the proper heat range. Iridium is 5 times stronger than platinum. Sorry but when I see that I feel I have to intervene. Oh and don't use any anti seize on the threads, the shiny silver is already a coating.
2012 Traverse LT2
bmcmahon42
« Reply #11 on: February 17, 2017, 08:02:32 AM »
Okay, thanks for the info.
whipster
Full Member
« Reply #12 on: February 17, 2017, 09:37:46 AM »
You bet, just trying to help. Many decades of experience talking
2012 Traverse LT2
« Reply #13 on: February 17, 2017, 10:06:32 AM »
whipster is correct.
Folks use those aftermarket plugs-- and soon report-- they had to go to AC DELCOs.
whipster
Full Member
« Reply #14 on: February 17, 2017, 11:50:03 AM »
Thanks! Good to hear the feedback. It's amazing how much a difference it can make.
2012 Traverse LT2
lookylou
« Reply #15 on: February 17, 2017, 12:17:51 PM »
Did you use the slightly more expensive Techron Concentrate Plus or the slightly cheaper regular Techron Fuel System Cleaner? Believe GM recommends the Concentrate for our DIs though it certainly couldn't hurt to use the regular one.
K & N Air Filter
Magnaflow XL Turbo
« Reply #16 on: February 17, 2017, 12:39:29 PM »
yes, the CONCENTRATE PLUS- is the one that GM uses in certain repairs.
it is sold at GM dealers under in a similar bottle as Techron.
It is also recommended in the Owners manual.
For customers who do not use TOP
TIER Detergent Gasoline regularly,
one bottle of GM Fuel System
Treatment PLUS, added to the fuel
tank at every engine oil change, can
help clean deposits from fuel
injectors and intake valves. GM Fuel
System Treatment PLUS is the only
gasoline additive recommended by
General Motors. It is available at
your dealer.
I see a theme going here...
« Reply #17 on: February 17, 2017, 12:44:59 PM »
ohhhhhhhhhhhhhh
even for use in their Direct Injection engines...
bmcmahon42
« Reply #18 on: February 17, 2017, 12:54:36 PM »
I used the complete fuel system cleaner 20z for 20 gallons on fill up.
« Reply #19 on: February 17, 2017, 01:14:32 PM »
good good good.
Some folks have mistakenly bought the box at Costco- thinking its the Concentrate Plus....
The Techron concentration in the Injector cleaner is low.
Has to be the Concentrate plus.
Pages: [1] 2  All   Go Up   [ Home | Unread Posts | Unread Replies ]
