February 20, 2017, 03:39:06 AM *
Pages: [1]   Go Down
Author Topic: how to adjust headlghts?  (Read 10246 times)
parky129
« on: June 01, 2011, 04:01:02 AM »
I have a 1011 Lt  and wonder how to adjust headlights for a little more illumination of road signs? Just a little adjustment not a lot, it is hard to see the signs without illuminating high beams. Thanks! wink
« Reply #1 on: June 01, 2011, 11:38:59 AM »
2 things....
Try Silverstar bulbs. These helped me see signs better.... but  you obvioulsly have to buy and install..
But- when you open the hood- in the area directly above the headlamp assembly- theres a small hole- next to it is an icon of a headlight.
I believe its a Torx bit that is required-- but you insert a screwdriver with the correct end-- and you can then turn it- this will slightly raise or lower the headlight beam.
What I recommend you do is park your car- at a certain distance from a garage door or wall- turn on your lights- and MARK the level of the beam.
Then you can slightly adjust. Dont forget that raising the level-- may put light in oncoming drivers eyes... especially once you add some passengers/weight to the back.
In case you want to return to the factory setting- park at the distance you had measured above- and lower the beam pattern to the marks you made on the wall.
Quantum
Global Moderator
« Reply #2 on: June 01, 2011, 03:48:28 PM »
I had the same issue when we bought our Traverse.
I did what rbarrios said, switch to Silverstars.  They made the difference for me, the signs are great now!
I didn't want to adjust my headlamp housings, because when I have the trailer hooked up, the rear of the Traverse settles, and I don't want to blind on-coming traffic.
2010 Traverse 1LT
Built 3/10 in Lansing, MI
Ontario, Canada
