March 29, 2017, 11:00:36 AM *
News: 2nd Annual Lambda meet/LDT plant tour Jun 17, 2011 more info
Pages: [1]   Go Down
Author Topic: Replacing taillight bulb?  (Read 15853 times)
imgntht
« on: January 13, 2011, 10:58:28 PM »
Does anyone know how to access the taillight bulbs?  My wife's '09 Traverse has already blown a bulb in the taillight so she has lost functionalilty of the brake lamp and the turn signal at the right rear.  Can you remove the taillight assembly itself, or do I need to remove the interior trim in the cargo area?
AA/78U-Blue Gold
Guest
« Reply #1 on: January 13, 2011, 11:03:09 PM »
If the assembly is anything like the Acadia; you will have to access the bulb from the interior
Toddzilla67
Hero Member
« Reply #2 on: January 13, 2011, 11:16:47 PM »
Removal of the tail light assembly should be fairly easy if access isn't available from the interior.  Raise the liftgate and look for the two red covers on the assembly.  Carefully pry those covers off and remove the nuts that hold the assembly, then carefully pull the assembly straight out without pulling the wiring too far.  Replace bulb, re-assemble.
2010 Traverse LTZ AWD
Born 11/09
Silver Ice Metallic, Titanium Leather
DVD, Nav, Sunroof, Towing
Just drive it.
Tiestosteele
Hero Member
« Reply #3 on: January 14, 2011, 09:18:39 AM »
Check out this topic : http://www.traverseforum.com/index.php?topic=659.0
You can remove the tailights without having to remove the backside of the lift gate. I took mine off in under a minute each
11 Jeep Grand Cherokee - Nav, Push Start, DVD
09 LTZ Black Granite Metallic, Nav, Dual DVD, True HID headlights, LED Reverse lights (SOLD)
04 Azure Blue Mach 1 - 5spd., tri ax shifter, bassani headers, magnaflow exhaust, custom xpipe, 4.10 gears, 17x10.5" 315 drag radials, custom tune.
AA/78U-Blue Gold
Guest
« Reply #4 on: January 14, 2011, 09:28:13 AM »
Nice pics and write up  thumbs up
Online Online
« Reply #5 on: January 14, 2011, 11:48:52 AM »
when I read his post- thats the exact thread I thought about.
imgntht
« Reply #6 on: January 19, 2011, 11:41:06 AM »
ToodZilla67's response is what I was hoping to hear.  The link to the other thread was relevant only for the reverse bulb and taillight section on the actual hatch.  The bulb that blew out was the brake light that is in the section attached to the rear qtr panel and wraps around the side of the car.  There must be a clip or it slides into the sheet metal somewhere in the "tip" of the light assembly so there is no need for additional screws there.
I'll also check the manual, as I hadn't thought about that...
Thanks.
